Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
iPhone 6 resets randomly/loose battery connector
Hi my iphone 6 resets randomly with every battery percentage and my battery health is 100% (3 month old).and when i opened the phone and disconnected the battery i find out the battery disconnects easily with no pressure and when i want to connect it again it jumps out after a while. So what can i do to solve this loose battery connector problem!?I’ve tried to put some paper under metal shield to apply some pressure on connector but its good for 1 day and the day after shut down / restart loop starts again.
Are you sure you got the right battery ? Sounds like the connector wouldn't be the right one, it shouldn't pop out when you release pressure. Correct iPhone 6 battery capacity should read as 1810mAh on battery wrapper.
Yeah battery is the right 1810mAh one.u know it was ok until my friend dropped my phone that was in charge on the floor from about 50cm height.after that phone wont turn on and i opened it and reconnected the battery and everything was fine for a few days. But now i must apply pressure to connector it didnt even connect a little and jumps out immediately!
https://ibb.co/XFpHjvC
And one more thing!when the phone is connected to power supply its ok no restarts at heaviest processes occures.
And I’ve uploaded a photo of connector from internet and my battery is not like this one and doesn’t have the red part ive mentioned in the picture and its kinda flat. And im so confused cuz i have an old battery like the photo and its not connecting at all like the new one.
@Mohammad Saghi Altough it's a bit unusual, the drop may have damaged the connector, hard to tell if on battery side or logic board side without the chance to close check. Check both connectors are firm with good light and some magnification if possible before buying a new battery. There 's really nothing more I can help with at a distance.
Hey!
It could be the battery that is faulty, i would try to put a new battery in and test it out.
If that doesn’t work i would recommend looking at your warranty.
You could be unlucky that they will deny you warranty because you already opened the phone.
The phone is not new and its out of warranty.
Yeah i can test a new battery but i dont want to pay more on this old phone
Tnx for ur answer bro.
Mohammad Saghi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 558
