Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
Problem with Sony home theatre no power
Hai
Anyone can give the solution for my doubt. I got Sony home theatre DAV-TZ135 no power. I check the smps primary section ok but no output supply. How to fix this issue. Can you give me your solution.
Thanks
crwdns2944067:04crwdne2944067:0
Hi @gajini
Possible to share some pictures?
what had you really checked?
Check for any blown / burnt components.
cold solders, open resistors, transistors, capacitors, can cause those
I have sony BDV-E2100 no power after thunder storm
@Saiful Hassan
Disconnect the power from the receiver and then open the receiver and check for any damage to the power board.
usually there is a fuse and a surge suppressor near to where the power cord connector is located so check them first.
If you see something or you are not quite sure take some close up pictures and post back here.
Here's how to do this. Adding images to an existing question
I have SONY HOME THEATRE DAV-TZ210, problem is when I volume up from 0 to 1 system show push power protector how can I fix
@gajini you may have to check the 5V voltage for the standby on connector CN901. It is possible that this is because your control board or standby board does not turn your power supply on. It will have power at the primary side but does not get turned on. You can download the manual from sites like this Let us know what you find and post some good pictures of your boards with your Question. Adding images to an existing question
Kannian paranthaman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,262
