The Ford Super Duty (also called the F-Series Super Duty) is a series of trucks produced by Ford Motor Company, an American automaker.
locate park light relay f-250
2003f 250 where is park light relay located?
Hi @shosteen
The owner manual for your model vehicle doesn’t show a relay for the parking lights but it has got a fuse for the exterior lamps.
Check if fuse #17 in the passenger compartment fuse panel is OK.
Here’s an image taken from the manual that shows the location of the fuse
(click on image to enlarge for better viewing)
Light switches are always burning if you dont find the problem elsewhere, open up the light switch and inspect for black spots.
Check wires at door jam inside rubber boot cracked shorting out
Relay is behind radio along with trnsignal flasher
Stephen Shooner crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,777
