Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
Why does the engine die when I give it some gas?
motorcycle is suzuki gd110. if the headlights are off, the engine won’t start. if i turn on the headlights, the engine will start but will stall when i give it some gas. it will only run if the headlights are on full high and the turn lights are on. horn is weak, turn lights don’t blink. no power to any light when engine is off. rectifier has been replaced and battery is fully charged.
@mikeyjr64 the only commonality between all those issues is either the ignition switch or the wiring harness. I would start by checking the wiring for any shaved or exposed cables, After that check your ignition switch.
Thank you for the diagram. With its help, I found that the wire running from the battery to the ignition switch was disconnected.
I need engine diagram of suzuki gd110
mykiel2000 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 865
