Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
Taking too long to fill rinse water
Kenmore 80 washer..LONG time to fill tub for rinse cycle. When finally fills can manually move dial just past rinse label & starts spinning draining no problem. That is on cold rinse.. when moved to warm rinse it got ALITTLE better.
Hi,
How long does it take to first fill on a cold wash cycle?
If it also takes a long time, check that there is sufficient water pressure from the cold water tap (disconnect machine hose and run water into a bucket to check flow) and also check the filter in the end of the cold water inlet hose connected at the back of the machine in case it is partially blocked with sludge.
If the cold water pressure is OK and the filter is clean and it still takes a long time for the cold water to fill the machine then there may be a problem with the cold water inlet solenoid in the machine.
You can also do the same checks on the hot water as well just to make sure that both supplies are OK.
What is the full model number of the washer?
kellie hatcher crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 581
