Why is my tv in mute without the mute button on?
My tv went mute last night but I click the mute button on and off and nothing happens. It remains mute. I went to settings/soundout / it's on optical, is that correct?
crwdns2944067:06crwdne2944067:0
Norma Maldonado that depends on how and what you have connected. Let us know what your TV's model is so we can try to assist you.
Hi,
Do you have anything connected to the optical output port on the TV, like a soundbar or stereo receiver etc?
If nothing connected switch the TV sound setting back to TV or internal speakers or whatever is indicated for the sound to come from the TV and not an external speaker system
I have a 2013 non smart LG tv and it mutes itself. I notice it when I have my HDMI cord connected to my phone for 4-10 minutes
my tv is lg tv 55un73 and iam facing same problem when i mute iy the sound close ok for 1 minute maybe and then it self again start volume
again same its unmute it self in 5 seconds
  1. Open the Settings menu either by using the button on your remote or if your remote doesn't have a Settings button, press the Home/Smart button, then click the Settings icon.
  2. Navigate to the Audio/Sound menu.
  3. Choose Sound Out, then select TV Speakers.
Try this! This might help you!
Regards,
Lewis
Brilliant Xfinity had no clue but this was genius!!!! Worked first try after being mute for 3 darn days lol thank you
I found this to be 100% accurate. It was entirely mute I tried everything that was suggested. Thank you this works perfectly
works only on tv speakers, with bluetooth speakers still a problem
Didn't work when I followed the logical instructions
@arthurnicholls
What is the model number of the TV?
What is the signal source i.e. video and audio, for the TV e.g. TV antenna, streaming device, modem etc.
If not an antenna can you prove if the sound from the signal source works on another TV?
If not an antenna, have you tried a different signal input type (if possible) from the signal source to the TV e.g. HDMI, Component video + audio, AV video + audio?
Is the TV audio normally heard coming from the TV speakers or an external speaker system connected to the TV?
or just try to unplug it then wait 10 seconds then plug it back
crwdns2944067:09crwdne2944067:0:
Brilliant! That actually worked. After following all the other steps found via Google, a simple restart was all it needed. Thank you!
It works by unplugging it but why it keeps doing it?
Same here.. please help to fully recover
I was having the same problems ty very much ☺️
My external speakers set on optical for sound worked great. After pushing a few buttons, The TV went into mute mode and will not come out of it for optical. It will go on using the TV in the TV sound, but it will not work with my external speakers (optical setting). The mute button just keeps popping up. It will not come out of mute. I tried the mute on the TV, the fire stick, neither work. So aggravating. Any kind words of help would be greatly appreciated. I have tried turning the TV on and off as well as the components. Didn't work. I tried changing back to TV. And then optical didn't work. TV soundworks fine, but I love my external speakers.
crwdns2934275:04crwdne2934275:0
Norma Maldonado crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 184
crwdns2942667:0crwdne2942667:0 66,359
