Android tablet released in January 2015. The Dell Venue 8 7840 has an 8.40 inch display with a resolution of 2560 pixels by 1600 pixels.
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
Baz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 94
