The Ridgid JobMax R2851 Series B can be identified by its model number: R2851- Series B. This device is 120 Volts, 60Hz, and 4.0 Amps.
How do you remove Sleeve Spacing Assembly?
how do you remove the metal from the Sleeve Spacing Assembly ? do you need a special pulley?
You could probably use a bearing puller tool? Or clamp some underneath it such that it's not gripping the axle but is providing pressure to the lip of the sleeve, then on a hard surface use a hammer to hit the axle.
Damage in any case here could compromise the quality and safety of the repair.
Ron crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 267
