wifi and bluetooth issues. In Redmi Note 3
While i’m trying to enable my phone wifi or bluetooth is not turning on or stable. Please help on this. Thanks in advance…
Hi @jibvi ,
Try starting the phone in safe mode and check if WiFi/BT turn on OK and remain stable.
If they do then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
If still no good in safe mode try a factory restore (also known as a hard reset) and check if this resolves the problem.
''BACKUP the phone BEFORE performing a FACTORY RESTORE as it will ERASE all your data and downloaded apps.''
Once the backup has been completed perform the factory restore using the phone’s factory restore feature.
Once the factory restore has been completed check if the WiFi/BT turn on OK and remain stable.
If still no good then you have a hardware problem.
If the WiFi/BT are OK, restore the phone with the backup that you made earlier using the phone's restore feature.
Once the phone has been restored to what it was before, check that the WiFi/BT turns on OK and stays on.
If so then the reset has resolved the problem
For bluetooth Wi-Fi problem solve aap kya Karen
Reset your smartphone wifi and bluetooth settings this will solve your problem
Redmi note 3 wifi and bluetooth not working problem solution
You can refer to this article
crwdns2942667:0crwdne2942667:0 5,448
crwdns2934271:0crwdnd2934271:0 pritomnandy00 crwdne2934271:0
@pritomnandy00
Did you try what is suggested in the answer below, you didn't say?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Not wi-fi bleututh problem solve
crwdns2934271:0crwdnd2934271:0 Dinesh kumar crwdne2934271:0
