PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Why won’t my controller charge?
Hey, so I just got this website for one question. I have a DualShock 4 controller, and multiple plugs that used to work, but now when I plug it in, they won’t charge it. This Happened for both of my controllers, and I can’t turn them on at all, or charge them, and I don’t know what to do. The chargers are kind of loose when plugged in, but all of them are so I don’t think that could be it. I need help, and I don’t know what to get to fix my issue. Anyone?
were you charging it from a wall outlet, or from the playstation
Update (10/20/2019)
most times if you charge the controller using a wall outlet, it will charge at 12 volts. the controller charges at 5 volts, so you fried the charging board inside the controller. you can get a new one here. if you charge from the wall again just make sure to use a 5 volt wall adapter.
crwdns2886500:0MicroUSB charging port assembly for the 1st generation (JDS-001) PS4 DualShock 4 controllercrwdne2886500:0
crwdns2934075:0crwdne2934075:0
DualShock 4 Controller Charging Assembly (JDS-001)
$5.99
I’ve tried both, and neither have worked.
but when it stopped working were you charging with a wall outlet.
because if you did, it sometimes breaks the USB port on the controller, and therefore you wont be able to charge it.
Nicholas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 140
