Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
crwdns2934591:0873crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Will disconnecting the front proximity sensor cause no sound
I have disconnected the front proximity sensor on both the iphone 7 and iphone 8 models to stop the bootlooping issue, and have lost just the selfie camera capability, however, this time around, I have issues with the speaker as well. I can only hear on headphones or speakerphone….I changed the speaker, and still have the issue…any ideas?
crwdns2942205:01crwdne2942205:0
Hello, I am well aware of the audio IC issue, and this phone doesn’t have it……so I am so frustrated….
Hey, is the contact disconnected atm?
If you disconnect it and that stops the bootloop then there is a fault in your front camera flex/als/proximity.
You need to replace it.
It controlls the screens brightnes, the front camera, the function where the screen gets dark when lifting it to your ear in a call, the earspeaker function beacuse that flex is the only thing that connects the earspeaker to the motherboard.
When you set the contact down to the motherboard besure that you get it down on both right and left side, sometimes it only gets down on one side.
Maybe I just misunderstood your troubleshooting, but if you disconnected the top ALS/proximity/front cam cable the top speaker will be disconnected too, that’s the only via to the logic board for it. Or do I miss something here ?
No, you didn't miss a thing, that is why it is driving me crazy, because this isn't the first time I have done it, and honestly, the only functionality lost was the selfie camera portion. I don't understand it myself, in fact, I don't even understand why disconnecting it stops the bootlooping in the first place, lol.
@iphonefanatik Probably you have a faulty component up there, hard to tell which one, but replacing the flex cable should fix all issues, a quite easy and inexpensive replacement. If issues would still persist then it might be something got damaged around the connector on the board, but that's not very likely on an iPhone 8. Make sure you buy a top quality replacement as cheap stuff might not support truetone.
Rachel Kelley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 407
