Space Bar doesnotwork properly
My space bar is not functioningright. Sometimes it gives me thespace,but most ofthetime is nospacebetween words.
I have left the "unspaced" words so that you can have a feeling about theproblem.
Thanks for your help,
Josue
Thanks... I finally solved my problem by removing the space bar and cleaning the little object that was blocking the space bar from going down.
It is tricky... I pulled the space bar up starting from the top corners (top meaning closer to the screen) using my nails. I pulled up slowly, but firmly. The whole space bar came out with the two metal "hinges". I removed the little thing that was blocking the space bar and replaced the space bar key.
The key is held to the keyboard by two different "hinges". The top hinge (closer to the screen side has two 90 degree angles bends. The bottom one only one. Enter the "hooks" of the top hinge in their slots on the keyboard (behind each one of the "footings"). Do it one side first, and then,the other). Proceed to align the bottom hinge (one 90 degree angle) with the little whole in the metal bracket that holds the top hinge. Make sure that the plastic scissors-like base are aligned and the inner loop one is hooked to the corresponding latch.
Bring the space bar key vertically onto the keyboard,making sure that the bottom hinge tips are aligned with the little whole in the latch for the top hinge. Press firmly. You will hear the click. Make sure to press on each of three "footings".
Hope it helped.
If you solved your own problem accept your answer so people can see that this is the accepted answer. Nice job!
would itbepossible for you to share a video of this. my spacebar isn't going back
crwdns2947515:0crwdne2947515:0
crwdns2947517:0crwdne2947517:0
Has anything been spilled on it? You need to carefully remove the spacebar and clean the switch and guides. Both should move freely and reset immediately. You can also use a USB keyboard until you fix yours. Ralph
Thanks for your response.
Nothinghasbeenspilledon it...I used to take older keyboards apart... How do I remove the keys? the same way as the older ones?
By the way, I need to bang the space for it to work.
Josue
OK here is a URL on repairing your keyboard. Keep scaning down--you'll get to it. Ralph
http://www.takeitapart.net/archives/macb...
Popping the key caps off with a pen/pencil should work just fine.
No -this url is only about replacing the hard drive. Not about cleaning the keyboard.
Josue Raimundo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 47,296
