Repair guides and support for motorcycles manufactured by Honda.
speedometer and tach lights not working.
i have a 96 honda gl1500 se. the dash lights work but the speedometer and tach lights do not. any thoughts?
  • Speedometers are unique in that some of them use physical cables instead of sensors, so a speedometer not working can also indicate a broken cable or stripped gear.
  • If one or more warning lights fail to illuminate when you first turn the key on, it usually indicates a blown bulb.
  • If none of the lights come on at all, check the fuses and wiring to the instrument cluster first.
  • If a warning light comes on and stays on when the engine is running, that usually indicates a problem with that specific system.
I am sorry I wasn't clear on the request. What I meant was everything is working properly except the lights on the speedometer and tach. Makes it very difficult to drive at night.
Speedometer light Horan not working
I have a splandarbike but many problam this bike Bhai is smoking and the noise is very directly and not speed
ken_choat crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 3,368
