My P20 Pro only has service when plugged into a charger.
I took my phone to a repair shop as i completely smashed my screen.
He managed to replace the screen but now my phone will only connect to Vodafone network when plugged into a charger.
If i remove the usb from the charging port it goes to no service
Sounds like the battery may have gotten disconnected and/or died.
Huawei P20 Pro Battery Replacement
Changed the battery and still the same issue. Replaced the Antenna as well. Any other suggestions?
@jayb_1991
I'm facing the same issue after replacing my battery's
were you able to solve your issue ?
Hi, same problem for me. After battery replacement, signal is ok only under charging or if I connect hear jack. Any suggest?
jayb_1991 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 715
