How to change ignition
Here are the instructions for replacing the switch:
Disconnect negative battery cable. Remove steering column upper and lower covers. Remove screw(s) retaining ignition switch to steering column. Disconnect ignition switch harness connector. Remove ignition switch. To install, reverse removal procedure.
hope this helps
crwdns2947821:0crwdne2947821:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 858
James Clark ignition what? You need to tell us what the issues are and what you are trying to accomplish. Try to use more than 4 words ....;->
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@James Clark Do you want to change the ignition switch assembly, if yes, do you also have a security system (anti-theft)? Typically you will need a hammer and very sharp chisel as part of the process but lets see exactly what it is that you need to do first please.
crwdns2934271:0crwdnd2934271:0 Duane Donaldson crwdne2934271:0
With lock cylinder, or without?
or,
Ignition module?
Ignition lockout/immobilizer?
Ignition relay?
More information required.
What are the symptoms, or how was the ignition diagnosed as the issue?
Help ‘us’ help you!
crwdns2934271:0crwdnd2934271:0 Mark A. Hemingway crwdne2934271:0
My bad, just saw someone covered those details, thank Turkey and Duane, they're right on point.
Regards.
