Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
very weak signal all networks
Hi,
I have a iphone 8 with very weak network signal. only picks up 1 bar and that is in and out. have tried different sims and resetting network settings , none of them have worked. only get 1 bar thats in and out on ee, vodafone etc. what part would need to be replaced? can find ones for wifi and Bluetooth but both of them work fine.
thanks
What you’ll want to replace is the Diversity Antenna. If you’re also having issues with Wi-Fi/BT, this could resolve those issues too.
have you ever changed the charging flex.WI-FI and bluetooth aerial is not Network antenna any more.Possible solution.
1- Antenna is connect to charging flex.
2- Bad contact of antenna to antenna connector.
crwdns2944067:08crwdne2944067:0:
Thank you will check tomorrow
I had the exact same issue. I replaced the Wi-Fi diversity antenna on my iPhone 8 (not the 8 Plus) and that didn't fix the issue. Rather replacing the top left antenna fixed my reception issue. Be super careful about the hidden screw on the side of the phone housing, it's a little bit difficult to see but as long as you have decent lighting like a lamp (like I used) then you should be able to see it. It's a little bit fiddly but not too awkward to take out the screw and put it back in but spending money on a replacement top left antenna is definitely better and way cheaper than buying a new phone. Details on how to replace your top left antenna are quite self explanatory but you can take a look on the iPhone 8 Charging Port replacement guide on iFixit:
iPhone 8 Lightning Connector Assembly Replacement
(Step 40, 41, 42)
update: I just realised there's also a full guide on replacing the top left antenna.
iPhone 8 Plus Top Left Antenna Replacement
I had the same issue. I replaced the down right antenna firstly and that didn't fix but top left. Thanks for sharing your experience about it Jordan Win!
@jw25116 Thanks for this helpful comment. Can you tell me where you purchased the top left antenna? It’s not sold here
Well I will suggest you to Update your software it might help you in fixing the issue.
dan morrill crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,117
