KitchenAid's Artisan Series 5 Quart Tilt-Head Stand Mixer model number KSM150PSER. All models starting with KSM150PS are the same device just different colors.
Meat Grinder Attachment Won't Grind...It Sticks
While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?
The problem is not with the attachment. It is in the Kitchen Aid mixer.
While the change in motor noise is most likely a motor fault, do examine the grinder itself. If the front ring is too tight, the mixer will grind (pun alert) to a halt.
If the grinder is adjusted properly, the motor’s worm-follower gear is the next thing to look at. It is designed to fail and save the motor from burning out.
The Service Manual can be found at:
++http://www.kitchenaidparts.eu/documents/...
Chuck Pelto crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,047
