KitchenAid's Artisan Series 5 Quart Tilt-Head Stand Mixer model number KSM150PSER. All models starting with KSM150PS are the same device just different colors.
crwdns2934591:020crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Meat Grinder Attachment Won't Grind...It Sticks
While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?
crwdns2942205:01crwdne2942205:0
The problem is not with the attachment. It is in the Kitchen Aid mixer.
While the change in motor noise is most likely a motor fault, do examine the grinder itself. If the front ring is too tight, the mixer will grind (pun alert) to a halt.
If the grinder is adjusted properly, the motor’s worm-follower gear is the next thing to look at. It is designed to fail and save the motor from burning out.
The Service Manual can be found at:
++http://www.kitchenaidparts.eu/documents/...
Chuck Pelto crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,940
