Orange LED blinks every 3 seconds
On Asus x540sa orange led starts blinking when left for charging
Try the following and see if it will turn on.
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds and see if the device will turn on.
5. If it does, great, now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.)
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if it needs replacing.
Just a quick reminder
If a computer isn't receiving a consistent flow of electricity, damage can and often does occur. In case of any unexpected error may occur, you’d better back up your computer on a regular basis.
Hope my answer comes in handy.
It works ok with the adapter. The battery is not charging even when left to charge overnight. The next morning I see the orange LED blinking every 3 seconds.
@csh080 Have you tried the steps I mentioned? Thank you!
Yes I tried the steps you mentioned Albert. Thanks for your help. I think my battery needs replacement.
@csh080 Thank you so much for your clarification, you may try with a new battery and see how's everything going. Any question, please feel free to ask, thank you!
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 3,275
Does your laptop shutdown or send you a low battery notification?
crwdns2934271:0crwdnd2934271:0 Vertinhol crwdne2934271:0
crwdns2934271:0crwdnd2934271:0 syed hasan crwdne2934271:0
