Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Fan Known Broken but no Power LED
Hi All, I have a Mac Mini (mid 2011) that I have been given the Fan is known bad and will order a replacement, could that cause the system to not power on at all as trying to trouble shoot the machine, any help would be amazing?
james
Before you order a fan, lets better understand why a dead system would even need a fan.
A dead system is often a bad power supply. It’s best to get the system working before you worry about the fan.
Mac mini Mid 2011 Power Supply Replacement
This series also had issues with its logic board. There are two versions ones with just the Intel intergraded graphics engine and a second version with a dedicated GPU chip.
The dedicated GPU models tend to burnout the GPU chip from heavy CPU and GPU processing loads as the cooling was just not up to the task of cooling the system.
So lets first ID your system to see which one you have as you maybe end up needing a new logic board as well!
Plug in the systems S/N here EveryMac - Lookup
Hiya, here is the Mac that i have.
Mac mini "Core i5" 2.3 (Mid-2011)
2.3 GHz Core i5 (I5-2415M)
Model: A1347 (EMC 2442)
James
@cosmicoofman - OK, you have the IG model Mac mini 2.3 GHz Core i5 (Mid-2011) Good!
Lets replace the power supply and see where we stand.
James Jordan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 110
