Find repair information on the second generation Toyota Tacoma.
4wD indicator and 4 low lights on
Hello , 2005 Tacoma 4WD light and 4Lo lights blinking when ignition on . 4WD is in op. Plug in snap on scanner to data link port , and everything works fine , lights go out . Unplug scanner and lights flash immedialty
Either your front add motor is bad or the 4wd selector switch is blown.
I’ll check the switch when I get home , it’s just does t make any sense that everything works as designed when I plug my scanner in , then quits when I unplug it , I’ll check the switch and the park neutral signal today
What was the fix? I am having the same issue right now...
Sean baldwin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 3,499
