The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Where would I find a replacement wire for these?
My cloud 2 wire got destroyed recently and i am looking for a replacement cable witch i could sauder back, i would like the original quaility and a for pin so the micraphone would work. The wire had many problems and in the end the jack got brocken in a acident, so i ended up just clipping of the wire from the board and now i have i headset with no wires
Hi @zucky
I have replaced headphone cables in the past with a double ended 3.5mm cable. I just cut off the end and soldered the wires to the breakout board inside the earphone chamber. Here is a quality one I have used that I liked:
https://www.amazon.com/gp/product/B01D9W...
To get the mic portion to work, this will be more complicated. You might need to cut the cable below the mic and vol controls and wire that up to the mic cables inside your headset.
Hope this helps
Did you find any difference in the audio quality after the replacement? My biggest worry is getting a dodgy wire so I'm tempted to get like Cloud Alpha detachable wire and snipping off one end to wire it up inside the cups. Any advice?
@zucky replacement wires are pretty much impossible to purchase separately. you can try and scour the auction sites and look for a headset that is broken other than the cables. Or you could post some pictures of where and how your cable is damaged to see if it is possible to repair. Adding images to an existing question
Mark zuck crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,032
