The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
iPad 6 Home Button metal contact ripped
Hello, I successfully managed to remove a cracked screen from my ipad 6, but right at the end, the rectangular metal contact halfway down the home button assembly ripped. Can I access my ipad contents if I wire this damaged home button in? Or is it vital to replace it?
If you mean the Touch ID button flex cable broke(the little grey metal rectangle attached to the flex itself broke),it is repairable by a microsolderer. Other than that,you can maybe go to accessibility settings,assistive Touch. This allows a virtual home button function on screen.
The Touch ID function is tied by software to the logic board itself. So it is not replaceable unless apple will program a new one,which they would not do since you’ve opened the iPad…you can buy a home button replacement,but you will lose Touch ID function. Only physically pressing will work.
The only way to repair your Touch ID flex cable is to have someone that microsolderer tiny things fix it for you.
Anu Anand crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,003
