How to repair a vfd 700
It has water damage and the speaker do not work
Hi @moon22,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronic parts stores), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you have to use it check the label to verify the amount of IPA.
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a video that shows how to dis-assemble your phone to replace the screen which whilst that is not the problem you’re having with the phone still may be of some help in dis-assembling the phone so that it can be cleaned.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Very useful information!
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 214
crwdns2942205:01crwdne2942205:0
Electronics Water Damage
crwdns2934271:0crwdnd2934271:0 prop man crwdne2934271:0
