I used to get the error 0xC1 on my Epson printer quite a lot when I first got it. At first, the problem seemed unknown, but after taking consultations from the experts, I came to know that it could happen due to mainboard failure or a problem with the cable connection. To resolve this problem on my device, I usually follow the following steps. You can also try them to fix the issue on your Epson printer.
- The first step is to open the printer scanner.
- Next, you should inspect the FFC cable connected to your device.
- Then, you are required to reassemble your Epson printer.
- Furthermore, check your system's mainboard.
If all these steps are unable to fix the 0xC1 error, then getting help from someone else could be a great option for you.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
