WiFi and bluetooth not working Huawei p30
What parts fixes the Wifi and bluetooth on Huawei p30?
So the phone has had a ‘attempted’ repair at another shop. The phone has been opened and probably stripped. The first thing I would check is if the coaxial antenna cable that goes from the main board to the daughter board at the bottom has been refitted. I’ve seen phones ‘repaired’ with half the internals missing. Also check to see if any components are missing, especially if the previous shop attempted any soldering.
If your phone is having WiFi and bluetooth problems, the two most common utilities for addressing this are the system updates and network settings.
First go into Settings > System > System Updates and make sure the phone’s software is up-to-date.
Then, go to Settings > Network & Internet > Airplane Mode to turn Airplane Mode on and then off again.
If this doesn’t work, perform a network settings reset in Setings > System > Reset > Network settings reset.
Finally, is all else fails, a factory data reset may be the only option.
Hello, I haven't found this anywhere. I get the Software part of the issues with bluetooth and wifi.
But I had a Costumer whom repaired their phone(P30) at another repair shop at which the bluetooth and wifi just disconnects by itself. Does anyone have an Idea of what part that need to get changed?
Any update on this?
does anyone know how to fix this?
i was told that the main board for the p30 needs to be replaced when the wifi and bluetooth switches off on its own.
@henricrepairs replace the main board, i was told that by huawei technician
Don’t worry it’s really easy to solve this problem you just have to reset your network settings after it your wifi bluetooth, network all these problem will be solved.
https://okadtech.com/huawei-p30-lite-wif...
Hope this will help you here it’s written how you can reset your network settings
The problem is that my phone refuses to allow communication with any network unless the distance between the phone and the modem is 3 cm
HUAWEI p30 is not working bluetooth ND wifi
Please help me wifi/Bluetooth working
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 167
crwdns2942667:0crwdne2942667:0 11,154
crwdns2944067:07crwdne2944067:0
Is there no other solution for the wifi/Bluetooth issue?
thanks
crwdns2934271:0crwdnd2934271:0 Ark am crwdne2934271:0
i would be happy if someone has a cheaper solution than to replace the main board which is a third of the phone price, because at present my P30 has no wifi and no bluetooth.
crwdns2934271:0crwdnd2934271:0 Rashen Pachkowdie crwdne2934271:0
So how to fix it
crwdns2934271:0crwdnd2934271:0 Nzeyimana1 Thomas crwdne2934271:0
Wife and bluetooth is not turning on
I need a way to get wifi and Bluetooth turn on
=== Update (05/23/2022) ===
Is Huawei p30 please I need to help me
Yes both are not working
crwdns2934271:0crwdnd2934271:0 Naison Govera crwdne2934271:0
crwdns2934275:02crwdne2934275:0
