Problems with a Frigidaire Dishwasher
Hello all.
I have a Frigidaire Model# FDB1500LFB0 and my problem is that…
after loading and selecting my cycle and hitting Start, my washer fills with water to the (I presume) proper amount of water in the bottom. The water is very hot. Then the system stops, and the only thing that will happen after opening it after this (anywhere from 3-15 minutes, I did this several times.) is that when the door is shut back and cancel pressed it will drain as normal. It was left to “run” once and the soap drawer opened, dumping the “pod” directly below it. The dishes had never had water on them and the “pod” was mushy from the ambient humidity, and in a spot directly under the drawer. If left on it will cycle through a fill/drain cycle but the spray-arms never move. I have cut the breaker to it on and off with no change.
Any help will be appreciated, thank you.
There's two pumps on my dishwasher. If yours is the same the larger pump is bad.
The smaller one is for draining
Hi @fidhne ,
I’m wondering if there is a problem with the wash pump part #70, either a faulty motor or pump or a power supply problem from the control board to the pump motor. Can you hear it running?
Looking through the parts list for the dishwasher, it has a separate drain pump so that might explain why the dishwasher drains but doesn’t wash.
If there is a problem with the wash pump, there are other suppliers online that may suit you better, rather than the one I linked above. It was only shown to give you an idea of where it is located and the cost of the part. Just search for FDB1500LFB0 parts to get results for other suppliers of the parts.
If it's the main pump there easy to change. Just a matter of cost and age of dishwasher mine at home is 20 years and works great.
I work at apartments and new ones work good but seem to have more issues. If you think yours will have more problems soon might be time to replace. But if like me you like maintenance most parts are reasonable.
Jason Finnie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,544
