Need to bypass BIOS password.
I have a Toshiba Satellite C675-s7322 That I bought at an estate auction, and there is a BIOS password? I have tried everything I can think of to bypass it. Any ideas?
There is no way to get past the Win7 password into an account.
It is possible to get into a WIN7 computer and make a new account.
try:
on Windows 7 , use F2 on cold start to go to “bootup options”, select
-Safe Boot with DOS command window, then in
the DOS window that should appear,  type in
Net user administrator /active:yes    {Enter}
then restart the computer, you should now see the hidden
account “administrator” login icon which does NOT need a
password, just click to enter .  It is an Administrator level
account which will allow you to CREATE A NEW
Windows USER ACCOUNT of new naming, via Control
Panel / User Accounts / Create Account.    If you set it
for Password access, be sure to write down the password somewhere !
BE SURE to give the new account full administrator privileges/access.
I usually make two new full Administrator Access Level accounts,
both password protected.
Exit and restart ;   check to make sure you can actually
sign in to your new account(s) .  (login to one, then use “Switch User”)
Open a DOS window , type in
Net user administrator /active:no      {Enter}
Restart computer;   your “invisible” administrator account
login icon should now have disappeared again !
BUT don’t try getting rid of an existing account that you
do not have the password for it, Windows
will want the account password in order to do that .
Shhh, don’t tell anyone !
grumpylumpy
Todd P Conroy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 502
