Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
TV wont turn on no standby light
My Samsung TV won't turn on its actually the un55mu6300 no standby light I replaced the power board and the main board and it still won't power on. This happened after a thunderstorm power outage. Anyone? If not power board or main board what can it be. Also the backlight turns on when the main board is disconnected from powersupply
seangosner this”backlight turns on when the main board is disconnected from powersupply “ in general means the issue is the main board but since you already replaced both, I would suggest that you measure the voltage on the connector between your power board and the main board. Let’s see if this turns on since there may be a possibility of a bad P-function board. Take some good pictures of all of your boards and the interconnect wiring between them . that way we can see what you see and try to assist you further.
Adding images to an existing question
seangosner crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 660
