Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
How do I activate my iPhone
The iPhone had an Apple ID that was blocked so we couldn’t sign out and the owner of the Apple ID couldn’t remember the answers to security questions. So we tried 4ukey, which removed (?) the Apple ID, so we logged in to a new Apple ID.
The iPhone couldn’t detect a sim and was always on “Searching”, so we decided to update the iOS through OTA. We downloaded the file but it will give an error saying unable to install update.
So we erased the phone and set it back to factory settings. We got stuck at the setup screen where it will not activate iPhone after the join WiFi screen.
I then restored the iPhone to iOS 12.4 via 3utools, since iTunes was gave an error 3630 (which I later found it to be “failed to copy preflight options”.). The issue persisted and now, it’s still stuck at the the “Unable to Activate” screen but now it says “No Service” with a warning sign by it instead of “searching”.
Connecting to iTunes, it gives “The iPhone ‘iPhone’ could not be activated because the activation information could not be obtained from the device”
On the Device information (using 3utools), it says “Unable to Read Data” for both IMEI, Baseband Version and Primary Number and Brickstate is set to True.
I saw someone say that without IMEI, you cannot activate the iPhone. Is there a way around this?
any help will be appreciated.
thanks
That is Hardware Issues.Apple with the IOS update makes that to activate the iPhone IMEI,Serial,WI-FI,Bluetooth needs to be match.So,on old IOS that problem is shown as error -1 now shows Unable to active.This fault was not solve by software that is the hardware related faults.
The baseband data is not present on the phone that the phone don`t have IMEI number check it out first.On the other hand if the fault was from BBCPU that can`t be solved but if it was from BBpmu that can be fixed.It needs hardware skills.If you have hardware skills that videos makes to solve that issues.
my iphone 7plus is baypassed i restore this imei number
Follow these steps
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone.
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
    • If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
    • If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
I’ve tried most of this. I didn’t encounter the others. Thanks for the reply
It not let me connect wifi
how to unlock my ipad
Kyle Davis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 3,235
