Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
iPhone 7 plus reboots randomly
I have an iPhone 7+ that reboots constantly. I can’t use it for more than 10 mins max without it rebooting but it is more common for it to reboot every 2-3mins. I’ve tried restoring the phone, doing a DFU restore and replacing the battery and nothing seems to help. Anybody seen this before?
Has this phone been dropped, repaired (prior to you changing the battery) or came into contact with water recently? Likewise, have you been using a low-cost charging brick and cable?
The symptoms resemble those of a water damaged device. Don’t be fooled by the fact that the iPhone 7 is water resistant…it’s not always so. A cheap charger can also damage the charging circuit which would also give you similar symptoms.
There are no signs of water damage in the phone (indicators still white and no water marks on shields) and to the best of my knowledge its never had a serious drop or been charged on a cheap charger for an extended period of time
@codyauch it only takes one time to damage the charging circuit on a phone... ideally u would need to try it with a battery u know is good and then test the charging with a USB ampmeter, to me seems more like a battery issue bought on by charging issues.
Does it still reboot every 2 minutes if u leave it alone and dont use it or does it reboot only when ur using it???
@c9679 it happens regardless of whether i'm using the phone or not
Cody Auch crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 380
