The Shark Rocket with DuoClean (HV381) is a vacuum created by Shark in 2016.
Shark Rocket Duoclean HV380 soft roll won’t spin under load
Shark rocket duoclean soft roll won’t spin. If I take the soft roll out, I can see the “gear” that it snaps into is spinning, but when I put the soft roll in and snap it back in, it stops. I figure it must have some sort of “slip” designed in so if there’s too much load on it, the belt is allowed to slip instead of snapping or burning out motor. I’ve disassembled the vacuum head to check the drive belts and found the belt pulley does indeed spin relative to its axel (which means axel spinning doesn’t necessarily spin the brush). There was also a lot of black dust around the pulley and on its tiny splines. Is there an insert that should go on the axel to make the pulley spin with it under higher load? Without the soft roll spinning, this vacuum doesn’t pick up anything on hard floors. When it works, it’s the best vacuum I’ve ever used (including Dyson).
I had the exact same problem, unfortunately I didn't fix this until today (2 years later) when my large brush roller stopped spinning on carpet and the green light would stay on. There are 2 screws that need to be tightened, one per roller head. For me, tightening those was enough. Some people recommend getting a new belt for the system but the belt was kind of hard to get for me. I also removed any stuck on lint or hair in both the rollers and the vacuum was working perfectly again!! If it doesn't work, contact Shark customer service, they could help you get a replacement motorized head for a lower price.
Lisa Davids crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 323
