Kenwood Model Eleven Power/Line Level Meter Adjustments
My receiver is the Model Nine G but the procedure should be the same.
When the needles are idle they are a little off from the 0 position.
It’s a “/ “  mark @ the bottom of the scale.
So my question is How do you adjust the needles to the 0 position ?
Thanks !
You mean that the needle doesn't reach the 0 position when the potentiometer is in minimum ?
Thanks for replying !
Lets say if the unit is powered off or idling in AUX mode, both L & R meters should have the needles resting @ the " / " mark on the bottom of the meter scale/dial.
There are internal pots for this & I don't know the procedure.
There must be a way of opening this up and rebalancing/re-adjusting the pins right?
I think you need to re-adjust them manually by reaching directly the needles, there is no other way.
Hamdi,
They are close to 0. One is a little off to the left & the other off to the right.
There is no manual adjustment. There are two pots for each channel for
line level & power/watts.
Brayden,
The unit is opened up & I have 4 pots staring @ me. The meters can't be opened.
I have the service manual guys & I just don't know the procedure.
