Repair and troubleshooting for the Brother Industries multi-function printer with model number MFC-J430W.
Unable to Print 4F Error Code
My printer (actually Brother MFC-J630W) gives me an error code: Unable to Init. 4F and/or Unable to Print 4F. It also indicates I should see troubleshooting in Users Guide which I can’t find.
my printer will not print in any color
Nanette Bergen
"Unable to Print 4F"
The message "Unable to Print 4F" will appear on the display for one of the following reasons:
     i.  A foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine;
     ii.  Mechanical malfunction.
To attempt to clear the error, continue to step 1.
1.  Using both hands, use the finger holds on each side of the machine to life the scanner cover into the open position.
Do you see the scanner cover support arm located on the left side of the machine?
          - If yes, go to step 2.
          - If no, verify you have opened the scanner cover (as in the image above).  If the document cover was opened, you won't see the scanner cover support arm.  Close the document cover and go back to step 1 to open the scanner cover.
2.  Carefully check the left (2) and right (3) hand corners and the center inside the machine and remove any paper scraps that may be jammed.
3.  Using your hand, move the print head from left to right, checking carefully for any paper scraps stuck under the print head.  Remove any if found.
      If the print head is in the right-hand corner, press and hold down the  for at least 5 seconds until the print head moves to the middle.  This will allow you to check the right corner inside the machine for any paper scraps.
4.  Leave the scanner cover open and turn the machine around so you are looking at the back of the machine.
5.  Open the Jam Clear Cover (1) on the back of the machine.
6.  Check inside for any foreign objects or jammed paper.  Remove it found.
7.  Close the Jam Clear Cover, then turn the machine back around to the front.
8.  Lift the flat-bed scanner cover to release the lock (1), then gently push the scanner cover support down (2) and close the scanner cover (3) using both hands.
  - If "Unable to Print 4F" still on the display, go to step 10.
     - If "Unable to Print 4F" has cleared, go to step 11.
10.  Unplug the machine from the power outlet for approximately one-minute, then plug it back in.
     - If "Unable to Print 4F" still on the display, go to step 12.
11.  Print a Print Quality Check Sheet (PQCS).
     a.  Press  on the Touchscreen.
     b.  Press Test Print.
     c.  Press Print Quality.
     d.  Press OK.  A PQCS will print.
          - If the PQCS print successfully, your machine is working properly.  The issue has been resolved.
          - If the PQCS doesn't print because "Unable to Print 4F" reappears and you have not cycled the power, go back to step 10.
          - If the PQCS doesn't print because "Unable to Print 4F" reappears and you have cycled the power, continue to step 12.
12.  Your machine will require service.  Any faxes received while the error message is on the display will automatically go into the machine's memory due to the product's inability to print.  If there are faxes in memory, you can transfer them to another fax machine so they are not lost.
     - If you don't want to transfer faxes, go to Warranty and Service Options.
     - If you want to confirm and transfer received faxes in memory, go to step 13.
13.  Transferring stored faxes to another machine.
           To transfer data from your fax machine to another fax machine, you must have already programmed the Station ID in your machine prior to getting the "Unable to Print 4F" error message.  If you did not already have your Station ID programmed into the machine before getting the error, you will not be able to transfer faxes in memory.  Continue to Warranty and Service Options.
     a.  Press  to temporarily interrupt the error message.
     b.  Press  on the Touchscreen.
     c.  Press All Settings.
     d.  Press ▲ or ▼ to display Service.  Press Service.
     e.  Press Data Transfer.
     f.  Press Fax Transfer.
          - If "No Data" appears there are no faxes in memory to transfer.  Press , then continue to Warranty and Service Options.
          - If there are faxes in memory, the display will prompt to enter a fax number.  Enter the fax number including the 1 plus the area code, then go to step g.
     g.  Press Black Start.  The stored faxes will transfer to that number.  Continue to Warranty and Service Options.
from here Let us know what happens.
I am sorry, i am very new to this. I dont see the picture you are talking about. Somehow i get only problems with my printer when i have windows updates. it always helped when i deinstalled some. but not anymore. My printer is used regularly but never too much and is taken good care of. i started using it 4 months ago. until then it was packaged. i had the exact same printer that i used for years and usually it was always relable. the model is:: brother dcp J 125 / LC 985. thank you for your help in advance. <3
Nanette Bergen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,660
