Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
Touch not working after writing screen data
First iPhone XS Max I received with damage in the display. The left corner was black and the rest works fine. Looks like it only cracked a little. The customer wanted to replace it because it cracked where you read the time xD. We have a DEMO model we only use for showing customers so I thought might as well swap displays..
I copied the display info and wrote it on our display but the touchscreen didn’t work. When I put back his broken display it works just fine.
I put back the original information on our display and the touch still doesn’t work on our DEMO model. I read online that this is a known problem when replacing XS displays but this is the original display.
Did I break our display or did it happen because I replaced the serial. I wrote back the original info. When I read the diaplsy it shows the original information.
Update (08/17/2019)
Was a tear in 1 of the flex cable where the strip of adhesive is. Was so small it was barely noticable. Changed another display and It works now. Might have accidently damaged it when taking of the display. Whoops
This may be a shot in the dark but make sure the phone is up to date. I have had one case where aftermarket digitizer on a refurbished iPad Air 2 touch screen not work because the iOS was too old like iOS 10 / 11.
What quality is the demo screen? Some may not support writing new display data properly to their display chip.
Display is the original display. It stopped working after I tried to swap it on another iPhone with a broken display.
KWH crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 346
