The GSM version of the second generation Samsung Gear round smartwatch running Samsung's Tizen OS. The Gear S2 with 3G GSM was released in October 2015. Model number: SM-R730A.
Replace the small black tap on the back
Gear Sport, Blue'''
MODEL NUMBER: SM-R600SERIAL
The black tap on black is gone. Need a replacement? Can anyone fix or can I order this part? Thx
It's not clear what part you are looking for. Can you provide a picture showing more detail? Thanks.
Picture was added for clarity.
This is the only replacement that I could find.
https://rounded.com/samsung-gear-sport-s...
If you do not have one, you will need a tri-wing screw driver. You will also need a splunger or a guitar pick or playing card to pry the back open once you remove the screws.
Here is a simple tear down guide for the Samsung Gear Sport.
Hope this helps. Good luck.
This is wonderful..thank you, thank you, thank you! I have ordered the back and screw driver and I am sure I will check out the guide once they arrive!
Lyn Hardway crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 230
