Charging Issue since 4 months
Charging with low power only, heat up. Not charging while shut down.
You likely need a new battery set the main battery is easy to replace following this guide iBook G4 12" 800 MHz-1.2 GHz Battery Replacement You also need to replace the PRAM battery which is located under the top shield just behind the ports. Follow this guide to gain access iBook G4 12" 800 MHz-1.2 GHz Top Shield Replacement. The battery guide has the info for the button battery.
crwdns2956074:0crwdne2956074:0
crwdns2934079:0crwdne2934079:0
crwdns2937585:0crwdne2937585:0
crwdns2937803:0crwdne2937803:0
crwdns2959996:0crwdne2959996:0 287
