Weak wifi signal after battery change
Hello. I changed the battery on my S7 & since then I have experienced a very weak wifi connection. I can no longer connect to the wifi in different rooms of my home. I have looked at the wifi antenna & everything looks fine. I did accidently pierce the old battery when I was taking it out & it got  very hot before I was able to remove it.  Any idea?
317/5000
Hi Guys, I also have the same problem, I changed the battery of my S7, and the signal of my wifi has decreased dramatically, I have verified that everything is connected correctly, and I couldnt solve this problem, T Burrows if you found Any solution please help me, I’ll be very grateful.
crwdns2942205:01crwdne2942205:0:
I am still experiencing the problem. I was wondering if it is a problem with the battery?
You’ve detatched the wifi antenna lead from the motherboard. The antenna is built into the top (black/brown) plastic shroud on the S7. You’ll have to open the phone again, and make sure it has no signs of damage, and is properly attached to the logic board.
T Burrows crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 575
