Wireless gaming headset released in October 2014. The Astro A50 (Model: 3AS50-PSW9N-383) can be used with the XBOX1, PS3, PS4, PC, and Mac.
One of the wires leading to the right earpiece is cut
Lost my headphones in the ground long time ago, it worked fine for a while with som tape. But finally one of the wires leading to the right earpiece got cut in half. How can I repair this wire?
It’s a bit tricky to tell from the photo but you should be able to solder this connection back together again.
Soldering is relatively simple, but you’ll need a soldering iron, and some solder to do it. You’ll also want to cut back the wrapping on the wire as to make sure you can get a good amount of wire. As an alternative you could also buy a cheap wire connector and just splice the two sides together… this isn’t a great way to fix this issue though.
Is there a diagram that shows which wires connect to which? I'm having the same issue
magnus_bergesen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 389
