What screwdriver do I need
Can someone link me a screwdriver from the ifixit store that can be used to open up a joycon
@andrewifix you need a Y00 bit for the backplate iFixit Precision 4 mm Screwdriver Bit Even better if you get the kit so you have all drivers for most common repairs Mako Driver Kit - 64 Precision Bits
crwdns2886500:0iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$39.95
crwdns2886500:0iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit.crwdne2886500:0
$2.99
For the inside of the Joy-Con, you will also need a Phillips #00: https://eustore.ifixit.com/products/phil...
@oldturkey03 gave you some good options, and you hopefully fixed your controller by now, but if you only need a fixed blade screwdriver to open your Joy-Con or Switch, iFixit sells a Tri-point* Y00 Precision Screwdriver
*AKA a Tri-wing screwdriver. It is different from an actual "Tri-wing" Screwdriver. If you are opening a Switch Joy-Con, the screwdriver tip should resemble a Mercedes logo and not a shuriken. These nuances between screw types and more are in this Nintendo Switch screwdriver wiki resource.
crwdns2886500:0Precision fixed blade screwdriver engineered by iFixit.crwdne2886500:0
Tri-point Y00 Screwdriver
$5.99
Andrew crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 50,896
