Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Earpiece/Loudspeaker sounds muffled after cleaning and 2 replacements
The earpiece wasn’t working as a loudspeaker, I could hear a bit of top end coming out but it didn’t sound as full as the bottom speaker when watching films or listening to music. I cleaned the grille, I played with settings, left and right balance, mono, hearing aid, noise cancellation. No dice. Then I reset the phone including full factory reset and setting up as new phone, and tried downgrading. No dice. I then replaced the earpiece and cleaning inside. No dice. I have just replaced the earpiece again with a genuine apple part. Nothing. It sound thin on loudspeaker, and calls sou nd muffled.
When I pan all the way to the left in accessibility and flip the phone (so that left and right switch sides), the speakers sound completely different, like the woofer has gone, but there is no woofer.
any one got any advise. Thanks in advance.
Sometime ear speaker flex makes that issues,if the same no dough that is the audio codec ic fault.
Have you tried running a brush along the top speaker and bottom speaker? It’s how I usually fix the low sound problem when trying to hear others during calls, before I used to open up the phone to clean it but there’s no need to with this method.
I dont really understand this problem it sounds like OP is expecting the earpiece to be as loud as the loudspeaker...
it really happened to me with my outlier air, just suck it with your mouth, just make sure it’s cleaned. it seems that you push the membrane too deep and the way you make it right is by sucking it.. easiest way is using your mouth.
Henry Dart crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,978
