add water stays on
No matter what i do the add water light stays on
There is a magnetic float sensor in your reservoir that is stuck in the down position. Fill up the reservoir to the max level and tap the side of the reservoir until the float is free (this works better if you remove the reservoir first). You can also use a magnet against the side of the reservoir by the float to help jiggle it free. If this doesn’t work, there is most likely an obstruction blocking the float sensor. Clean the reservoir thoroughly.
I cannot for the life of me put the piece that holds the floater in place in the reservoir back on. Which direction does it go?? Please!!
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 465
