Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
How can I use ps4 pro slim from UK to US?
I recently bought a ps4 pro slim from Amazon UK and It turns out that the plug is different which I didn't notice that it will be different. So I'm trying to find some answers about which should I buy? Adapter, power cord or converter? I'm scared cuz the manual said is only 220-240v only. Hopefully someone could help with this issue.
Tripzter08  it is not necessary to use a transformer. Your PS4 Pro uses a Worldwide Universal power supply. All you need is the power cord to fit your electrical outlet.
The PS4 pro uses a 100-240v power supply, so pretty much all wall socket power should be good.
Find a plug that fits your outlet and wire it to a connect for the PS4s power.
As long as you make are the cable is good, and won’t short for any unexplicable reason, you will be good.
Just so you can read yourself, I linked the user manual pdf below so that you can be sure.
Check the first box of stats…
Happy gaming.
PS4 manual pdf link
https://manuals.playstation.net/document...
You said you manual said 220v-240v are you sure? I don't want you to blow the new baby immediately.. can you double check maybe upload a pic of the version number?
Get a step-up converter from 120v AC to at least 220V AC. If you can, try and get one with a circuit breaker or fuse, in case your machine draws too much. Also, maybe grab a US to UK adapter.
Try this:https://www.amazon.com/Goldsource-STU-50...
Good Luck!
crwdns2889612:0crwdne2889612:0 -1
Tripzter08 crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 82
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 1,042
