The Toyota Yaris is a subcompact car produced by Toyota since 1999. Between 1999 and 2005, some markets received the same vehicles under the Toyota Echo name. Toyota has used the "Yaris" and "Echo" names on the export version of several different Japanese-market models.
car rpm up and down
i have opel corsa type c 2003 one liter when i drive that car on moterway upto 60 miles its start missing and rpm up and down and maintainhence sign come on meter but after few minutes its normal and maintainhence sign still display on meter until i turn off the engine i showed to my mechanic he check the codes with computer and it showed that there is misfire in cylinder 3 we change the coil but have still same problem when i restart the car its start normal and maintainhence sign disappear after few minutes
I have corsa type c is overheating
@sello72330 year and engine size? what have you checked? How does it overheat? Do you see it actually being hot or is it just the display that says it's overheating? We need more detail in order to try and help you.
Try bringing it back to the manufacturer?
no i cant get you
Got it. It may either be a problem with the gauge, or the actual engine, but overall, never try to service these types of things with proper training. The most likely thing at this point with the given information (I had to decipher your question, try to space things out to make them more clear) it may be a computer wiring problem or a computer problem.
singh20893 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 912
