The Propel Spyder XL is a stunt drone with an HD camera manufactured by Propel.
crwdns2934591:08crwdne2934591:0 crwdns2934593:0crwdne2934593:0
I broke a propeller blade and the screw is broken
I have a propel graviton drone and I broke a propeller blade and go to change the blade and the head of the screw is gone but can still see the remainder of the screw holding the blade on to the “driveshaft" and can't take the blade off how do I get the rest of the screw out to successfully replace broken blade?
Are you talking about the Phillips Head screw that secures it to the shaft? If so how much of it is still sticking out? A photo would help us to answer this better
https://www.youtube.com/watch?v=_R-tVb5-...
I have exactly the same problem with a DJI Mini 3 Pro.
I have thought about looking for an expert in soldering circuits or something similar, to try to solder an extension to the headless screw and try to turn it until it is removed, but I see it as extremely difficult given the very small size of the screw, the solder point can easily spill towards the driveshaft and make it worse.
I am about to undertake this search for someone who is an expert in this.
If you have any other solution, I will greatly appreciate it.
This is the broken screw, just that little black point in the center of the driver shaft.
And these are some pics of the screw in good condition.
Sean McCurdy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 409
