Location of ECT Sensor 1 on top of motor
I can not find the ect location on top or side of motor. Already change ect 2 on radiator just need to figure out where #1 is located
@mgd1216 ECT 1 is under the air cleaner assembly. You need to remove the air cleaner to get to it.
can you sell me where the crankshaft sensor is? i see its on the diagram but is it front back or rear of the engine ?
@robertjohn11533 it is on the front of the engine
how do you remove the air cleaner to get to ECT 1
You need to unscrew the two screws holding the filter housing. Unscrew the clamp between the top of the housing and the throttle and remove the clamp that also connects another accessory to the filter housing.
In Polish:
Trzeba odkręcić dwie śruby trzymające obudowę filtra. Odkręcić obejmę pomiędzy górą obudowy, a przepustnicą oraz zdjąć obejmę zaciskową która również łączy inne akcesorium z obudową filtra.
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 291
crwdns2942667:0crwdne2942667:0 12,841
How can I remove ECT 2..?
crwdns2934271:0crwdnd2934271:0 NBT crwdne2934271:0
