A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
crwdns2934591:0239crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why there is horizontal lines all over my MacBook Pro screen?
Yesterday I was working on an essay for my class when suddenly horizontal lines appeared all over the screen. I just realized when I opened a navigator, because these lines don’t show on black/white background. I tried to reboot and nothing happened. It seems like a hardware issue since I rebooted my MacBook with Windows 10 (I have this other OS installed via bootcamp) and the same problem appeared.
My MacBook is off the warraty, is there any way to fix it without paying hundreds of dollars for a screen replacement?
My laptop Is a late 2016 MacBook pro with touchbar
Thanks
If this is another broken cable, no. You need to replace the screen.
Go to Apple then in the future maybe they will give a refund if this continues to get ugly.
Are you still seeing lines? The only experience i had with lines going horizontal on my screen was when my laptop was cold. Once it warmed up I saw them slowly disappear. It was kinda eerie.
Yes, I am still seeing them. :(
I'm so sorry. This likely means your screen is showing signs of failure. I hope this isn't the case! I'd get it checked out for sure and please let us know what they say.
I made a genius appointment in an official Apple support center. They told me that it might be a problem with the screen. And that I might replace the whole screen. I am now trying to reach the official support. I've already called them and explained my problem. I hope that my MB enter as an exception in that recall program that just appeared for people who have problems with the flex cable. Thanks for the help.
Macbook Pro 2016, with horizontal lines
This started while I am traveling abroad, with no Apple Store in sight.
After reading the comments, I tried the following:
With the display open at 40 degrees, I reached in and pressed firmly down onto the right hinge, then slowly opened the laptop to my preferred viewing angle. What I was trying to achieve is to "hold the ribbon cable in place" while opening.
This seemingly worked, as there are no more lines, until the next time.
Of course, I don't know how long this will work, or if it may damage other parts if used too often.
All I want is that this works until I am back home (another 10 days) and I can bug my favorite Apple Store to provide a hopefully free repair.
To verify the diagnosis, hook it up to an external monitor. If the, monitor displays the same lines, then your GPU is failing.
It's normal with an external monitor
That isolates the problem to your display or display cabling.
mario.minor crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,880
