Repair guides and support for a wide range of recreational vehicles.
Speedometer not working but all other gauges are? Solved
I have a 2005 Gulf Stream class A motor home on a Ford V-10 chassis. I went to take the motorhome out and the speedometer doesn't work but the odometer and trip meter do. Can anyone tell me what the problem may be and where the part is located to fix this problem. I did try and replace speed sensor in the rear end but didn't fix the issue I'm sure its something easy to fix but hoping someone else has had this issue
Update (05/30/2019)
Ok just for anyone else out there having this issue with your speedometer I had to send it out and have it repaired apparently this is a issue with a lot of different instrument clusters but this was my CLUSTER/SPEEDOMETER number 3C3F10849MA they had to replace some internal parts but now is working again like it should and at a great price. If you want more info contact me
crwdns2944067:06crwdne2944067:0
This question was migrated from https://meta.ifixit.com/Answers.
I have to drive my car 2 to 6 miles before the speedometer starts to work what do I do
I have a1994 Lincoln continental I have to Drive 5or10 miles before it starts to work ????
I won't saner not a question
Sorry But I have this problem for a long time and I can't get a asner either????? So I thought I would try
This may not help you fix this but just a tip. If your speedometer doesn’t work, it can be many things. Some cars have a cable and some are digital. If the cable is broken then it needs to be replaced. If its digital then it can be the speed sensor, ECU or just bad wires…
Dennis crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,881
