The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Unable to flash official ROM due to FRP block
My phone went into a boot loop and now it boots right into download mode or displays a message saying connect to Samsung switch and do an emergency repair.
Connecting to Samsung switch or kies doesn't work as it does not detect that the phone needs an emergency repair.
This lead me to using Odin and downloading an official ROM from Sammobile. I have made sure to download the correct file however, when flashing with Odin, the process fails at the end with the phone displaying a message saying something about FRP lock.
This is a problem since download mode is the only mode my phone will boot into so even though I know my email and password, I don't get to the screen to enter it.
What are my options in this case? How can I fix the software issue or bypass the FRP lock so that I can fix my issue?
same problem with me , any fix please
Have you tried booting into the Recovery Mode ?
  1. Power Off the Galaxy Note 5 (if you cant remove battery then put back on)
  2. Press and Hold the Power Button, Home Button and the Volume Up Button at the Same Time.
  3. Continue Holding These Buttons Until You See Some Blue Text at the Top of the Screen.
  4. When You See the Text 'Recovery Booting', Then You Can Let Go of These Three Buttons.
  5. tried factory resetting your phone
This won't be possible since I cannot enter recovery mode at all. The device is stuck at the 'Installing System Update' screen and sometimes it goes to 32% and then says No Command with a fallen down android man with a yellow triangle on it.
The button combos to enter recovery mode don't do anything. The only mode accessible is download mode.
Vex crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 741
