Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
crwdns2934591:0873crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone 8 in infinite bootloop tried everything and EVERYTHING
So after i updated my iphone 8 to ios 12.2, my phone started going on an infinite bootloop i tried everything dfu mode recovery mode no avail. sometimes when it comes off battery I can actually get it to the start screen and even set it up, but when it loses battery/ shuts off its bootloop again. I even removed battery and plugged it in with charger and it still bootlooped. I dont understand the problem AHHHH
crwdns2942205:01crwdne2942205:0
ALSO when it does get to the start/hello screen the haptic feedback doesnt work
Could be just a bad battery. Try getting that replaced and see how that goes.
iPhone will just flash apple logo on and off with battery disconnected so it needs a working battery for the iPhone to turn on.
really? How come the phone works when I do my little trick thingy until it gets powered on again. During this time the battery works just fine.
all though after the update it was working fine until it randomly shut off
If the phone works fine when the battery is charged but does not when it drops to a certain percentage that points to a bad battery.
The phone works with all percentages battery doesn’t seem to be a problem
Get New Battery. that’s your problem
but it works fine when I get it to homescreen zzz
Ah ok. Did you change the screen?
-- test audio also. Can you put the phone on speaker during phone call?
No I can’t put the phone on speaker during a call
If the speaker phone is greyed out during calls and voice memos record shows no recording device found then the phone has an audio IC problem.
To get that fixed the phone will have to be taken to a reputable phone repair shop that does micro-soldering.
this is what is causing the bootloop?
If you haven’t already fixed this, I have found that disconnecting the front proximity sensor altogether works, however, you lose the selfie camera feature…..
Levy Nguyen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 148
